Error code 1 to 30 or 50 to 200 or 300 is displayed
This error indicates a communication problem with a server at Sony side or third party side. The problem is often temporary and may automatically resolve after a while.
1. As a first step, retry access after a brief interval (1 minute).
2. Not solved? Update your TV to the latest system software directly via the Internet or manually via USB stick , and check whether the problem is resolved.
If the problem persists, you can contact us for further assistance.
