Article ID : 00135071 / Last Modified : 11/03/2016Print
Can I use YouView on my Android TV without an aerial?
    You will need an aerial to enable YouView and to have retuned your TV to a UK digital TV signal at least once, thereafter if the aerial is removed you will only be able to watch On Demand and use the search features (Internet required).
    For the best experience, we recommend using both an aerial and an Internet connection.
    NOTE: YouView does not work with a satellite dish.
