Article ID : 00139260 / Last Modified : 04/01/2016Print
Phase-detection AF support for A-mount lenses
    IMPORTANT: A firmware update (Ver. 2.0) of the camera is required for using Phase Detection AF.
    The ILCE-7M2 offers Phase Detection AF that provides better AF response compared to conventional Contrast AF, even when using an A-mount lens connected via adaptor LA-EA3 or LA-EA1 that is not equipped with a dedicated phase-detection AF system. As a result, wider AF coverage area, higher number and higher density of AF points can be used.
    NOTES:
    • Fast Hybrid AF is not supported when using Contrast AF
    • Full-frame shooting is not possible with the LA-EA1/LA-EA2 (shooting becomes equivalent to using APS-C size image sensor).
    List of A-mount lenses compatible with Phase Detection AF when mounted via LA-EA3 or LA-EA1 mount adaptor.
    NOTES:
    35mm Full-Frame lenses
    APS-C lenses
    Vario-Sonnar T* 16-35mm F2.8 ZA SSM (SAL1635Z) DT 16-50mm F2.8 SSM (SAL1650)
    Vario-Sonnar T* 16-35mm F2.8 ZA SSM II (SAL1635Z2) DT 18-55mm F3.5-5.6 SAM (SAL1855)
    Vario-Sonnar T* 24-70mm F2.8 ZA SSM (SAL2470Z) DT 18-55mm F3.5-5.6 SAM II (SAL18552)
    Vario-Sonnar T* 24-70mm F2.8 ZA SSM II (SAL2470Z2) DT 18-135mm F3.5-5.6 SAM (SAL18135)
    28-75mm F2.8 SAM (SAL2875) DT 55-200mm F4-5.6 SAM (SAL55200-2)
    70-200mm F2.8 G (SAL70200G) DT 55-300mm F4.5-5.6 SAM (SAL55300)
    70-200mm F2.8 G SSM II (SAL70200G2) DT 30mm F2.8 Macro SAM (SAL30M28)
    70-300mm F4.5-5.6 G SSM (SAL70300G) DT 35mm F1.8 SAM (SAL35F18)
    70-300mm F4.5-5.6 G SSM II (SAL70300G2) DT 50mm F1.8 SAM (SAL50F18)
    70-400mm F4-5.6 G SSM (SAL70400G)
    70-400mm F4-5.6 G SSM II (SAL70400G2)
    Distagon T*24mm F2 ZA SSM (SAL24F20Z)
    Planar T* 50mm F1.4 ZA SSM (SAL50F14Z)
    85mm F2.8 SAM (SAL85F28)
    300mm F2.8 G (SAL300F28G)
    300mm F2.8 G SSM II (SAL300F28G2)
    500mm F4 G SSM (SAL500F40G)
    Focal-plane phase-detection AF coverage and number of AF points used, with respect to a type of mounted lens.
    Mounted lens
    (incl. A-mount and E-mount lenses)
    Image format Phase-detection AF coverage AF points
    35mm full-frame lenses Full frame 20% 117
    APS-C 45% 117
    APC-C lenses APS-C 38% 99
    NOTE: The image format can be selected under APS-C/Super 35mm in the camera menu.
