Article ID : 00137158 / Last Modified : 04/12/2015Print
Lock-on AF cannot be set when an A-mount lens is attached
    Lock-on AF cannot be used when the A-mount lens adapter LA-EA2 or LA-EA4 is attached and Eye-Start AF is set to On. Follow the steps below to deactivate the Eye-Start AF function.
    1. On the camera, press the MENU button.
    2. Select Custom Settings.
    3. Select Eye-Start AF.
    4. Select Off.
