Article ID : 00149885 / Last Modified : 16/01/2026Print
Precautions when placing the CAS-1
    Please make sure of the following:
    • Do not orient this product horizontally. Only operation in vertical orientation is guaranteed
    • Speaker bases that prevent the speakers falling over are supplied. Place this product on top of the speaker bases for use
    • Do not place anything on top of the cabinet that might cause malfunctions
    NOTE : Also refer to the recommendations from the Operating Instructions.
