Article ID : 00155797 / Last Modified : 07/02/2019
How can I turn on/off the Usage & Diagnostics information for Sony's Android TV?
    You can choose whether you wish to help improve your Android TV by automatically sending diagnostic and usage data to Google. You can check your settings by going to:
    [Home] > [Settings]* > [Personal - Usage & Diagnostics] > [Yes/No]
    *For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner.
    Home
     Android - Home
    Settings
    Android - settings
    Settings: For Android Oreo (OSV-O), the settings iconSettings iconis located in the top right-hand corner.
    Personal Usage and Diagnostics
    Yes/No
    Improve Android TV
    NOTE: The screenshots provided here are for reference only. The actual screen might differ slightly according to your country, model or firmware version.
