Article ID : 00159322 / Last Modified : 12/07/2018
Can I use my Walkman while charging it?
    The Walkman can be used depending on the charging procedure. Please check as follows:
    • When using an AC adapter (sold separately), the Walkman can be used while charging.
      Charing your Walkman via an AC adapter
    • NOTE:
      • The temperature of the Walkman may increase while charging.
      • While charging, the electric power is shared from the battery to play the Walkman player. The AC adapter will continue to charge the battery. Therefore, playing music while charging does not cause the battery to further deteriorate.
    • If you connect the player to a PC via supplied USB cable to charge, you cannot use your Walkman while charging it.
      Charging your Walkman via a PC
    • NOTE: When connecting to a PC, "Connected USB" will be displayed, and you will not be able to use your Walkman.
