Steering Wheel Control Compatibility for Japanese cars
General Notes
- Compatibility is only confirmed with the Japanese Car Manufacturing companies listed below.
- It is recommended that all car stereo installations be performed by a qualified, professional installer.
- Car manufacturers can change the wiring specifications without notice. Be sure to locate the correct wires before beginning installation.
- Please refer to the operating instructions or contact the manufacturer of your car or car dealer for more information.
- All connections shown in this chart are from the wire side, not the terminal side.
- Be sure to connect each lead properly to avoid damage.
- Cover any unused leads with electrical tape for safety.
- Do not connect the cable if you are not using the steering wheel control feature.
- This information is subject to change without notice.
You need an RC-SR1 (cable) to perform steering wheel remote input.
NOTE: Purchase RC-SR1 (CONNECTION CABLE(SW)) Parts Number: 1-848-796-11 as a service part.
[2] Input 2 (Red or Brown)
[1] Input 1 (Green)
[G] GND (Black)
Manufacturer |
Connector Type | Pin Assignment | |
TOYOTA |
20P |
Input 1: 1 |
TOYOTA |
26P |
| Input 1: 1 Input 2: 2 GND : G |
TOYOTA |
28P |
HONDA |
20P-A |
| Input 1: 1 Input 2: (NC) GND : G |
HONDA | 20P-B |
HONDA | 24P |
NISSAN | 16P-A |
NISSAN | 16P-B |
NISSAN | 20P |
MITSUBISHI | 20P |
MAZDA | 24P |
SUBARU | 8P |
SUBARU | 20P |
MARUTI SUZUKI | 20P |
