XAV Steering Wheel Control compatibility
General Notes
- Compatibility is only confirmed with the Japanese Car Manufacturing companies listed below
- Sony recommends using a professional for installation.
- Car manufacturers can change the wiring specifications without notice. Be sure to locate the correct wires before beginning installation.
- Please refer to the operating instructions or contact the manufacturer of your car or car dealer for more information.
- All connections shown in this chart are from the wire side, not the terminal side.
- It is recommended that all car stereo installations be performed by a qualified, professional installer.
- Be sure to connect each lead properly to avoid damage.
- Cover any unused leads with electrical tape for safety.
- Do not connect the cable if you are not using the steering wheel control feature.
- This information is subject to change without notice.
XAV Cable (not supplied)
Car Wiring Configurations
Manufacturer | Connector Type | Pin Assignment | Notes | |
Toyota | 20P | Input 1:1 Input 2:2 GND = G | ||
26P | Input 1:1 Input 2:2 GND = G | |||
28P | Input 1:1 Input 2:2 GND = G | |||
Honda | 20P-A | Input 1:1 Input 2: N/C GND = G | ||
20P-B | Input 1:1 Input 2: N/C GND = G | |||
24P | Input 1:1 Input 2: N/C GND = G | |||
Nissan | 16P-A | Input 1:1 Input 2:2 GND = G | ||
16P-B | Input 1:1 Input 2:2 GND = G | |||
20P | Input 1:1 Input 2:2 GND = G | |||
Mitsubishi | 20P | Input 1:1 Input 2: N/C GND = G | ||
Mazda | 24P | Input 1:1 Input 2: N/C GND = G | ||
Subaru | 8P | Input 1:1 Input 2: N/C GND = G | ||
20P | Input 1:1 Input 2: N/C GND = G | |||
Maruti Suzuki | 20P | Input 1:1 Input 2: N/C GND = G |
