Article ID : 00169486 / Last Modified : 10/03/2020
What is the recommended application for playing back music files on a PC? (TA-ZH1ES)
    The recommended application is Hi-Res Audio Player (Ver.1.2.5 or higher).
    Media Go can also be used.
    NOTE: Media Go is not compatible with the following sampling frequencies: DSD 22.4 MHz, PCM 768 kHz, PCM 705.6 kHz.
