Article ID : 00173729 / Last Modified : 10/05/2022Print
What is the "Panel Refresh" function?
    The Panel refresh function is available for models equipped with an Organic EL (OLED) panel and is used to prevent image retention.
    Panel Refresh adjusts the panel uniformity of the TV screen after it has been in use for long periods of time.
    You can perform a refresh manually when image retention is noticeable.
    However, please do not perform this function more than once a year, as it may affect the lifespan of the panel.
    If you want to run the Panel Refresh function, please follow the steps below:
    1. Press the HOME button on the remote.
    2. Select  Settings following the steps below:
      • You can use the  Quick Settings button (For models released in 2019 or later)
        1. Press the  (Quick Settings) button on the remote control.
        2. Select  Settings.
      • You can use the HOME button
        1. Press the HOME button on the remote control.
        2. Select  Settings.
    3. The next steps will depend on your TV menu options:
      • Select Display & Sound → Expert panel settings → Panel refresh.
      • Select Display → Expert panel settings → Panel refresh
    NOTES:
    • Due to the characteristics of the materials found in OLED displays, pixels may degrade and unevenness may become apparent on the TV screen.
    • Performing a Panel Refresh may take approximately one hour to complete.
    • A white line may be displayed on the screen during the refresh process, this is not a malfunction of the TV.
    • This function will only work when the room temperature is between 50 ºF and 104 ºF (10 ºC and 40 ºC).
