Using the TV Menu / TV Menu Bar
For Android TV™ models released in 2020 or later & the models listed below:
- A9G_AG9, XG85_X85G_U8G (55/65/75/85), XG95_X95G, Z9G_ZG9 series
- A9F_AF9, Z9F_ZF9 series with Android™ 9
Press the TV button while watching a TV broadcast to display the TV Menu.
You can check other TV programmes while watching the current TV programmes. You can also change to a channel you often watch with one action.
If you want the TV Menu to disappear, press the TV or BACK button.
Other TV models
Press the TV button while watching a TV broadcast to display the TV Menu Bar.
You can check other TV programmes while watching the current TV programme, and you can also change to a channel you often watch or switch to the app you’ve used recently with one action.
If you want the TV Menu Bar to disappear, press the TV or BACK button.
