Article ID : 00203244 / Last Modified : 27/06/2019Print
Issues casting to the TV with Chromecast built-in
    You may be experiencing issues casting content from your smartphone or tablet onto your TV.
    If you’re facing the symptom mentioned above, please try the following steps:
    1. Clear data and Clear cache from the Chromecast built-in app. From the Home screen:
      • Select [Settings]
      • Select [Apps]
      • Select [Chromecast built-in]
      • Select [Clear data]
      • Select [OK]
      • Select [Clear cache]
      • Select [OK]
        Chromecast built-in: Clear data
    2. Restart the TV by holding the green standby button on the remote for more than 5 seconds and release when the TV screen goes black.
