Article ID : 00206844 / Last Modified : 25/05/2022Print
How to adjust the volume of my smart speaker by using Google Assistant.
    In order to adjust the volume by speech command using Google Assistant, face the smart speaker and speak aloud the percentage you want to set the volume to (0 - 100), followed by "percent".
    For example, if you want to set the volume to "5", tell Google Assistant "volume 5 percent".
