Can't use Google Play Music on my smart speaker
Check the terms and conditions of the Google Play™ Music service if you encounter an error or can't play music files. If you're using a free trial service, the trial period may have ended. You need a subscription to Google Play Music to continue the use of its services.
For more information, contact the Google Play Music service provider.
