Article ID : 00230244 / Last Modified : 19/01/2026Print
    Cannot connect the TV and Sound Bar using Bluetooth. (HT-S100F/SF150)
    This may occur if the Bluetooth function of your HT-S100F soundbar is off. To turn it on, press and hold the Power(power), Input(input select), and - (volume) buttons on the soundbar at the same time for more than ten seconds.
    Note: The USB indicator flashes twice when Bluetooth is on. If it's off, the USB indicator flashes once.
    If the issue still occurs, follow these steps to reset your soundbar:
    1. Press and hold the Power(power), Input(input select), and + (volume) buttons at the same time for more than five seconds.
      • All indicators on your soundbar will flash three times.
    2. Unplug the power cord and plug it back into a working outlet.
    3. Turn on your soundbar.
