Article ID : 00238862 / Last Modified : 20/01/2026Print
    The battery level icon on the status bar flashes red and white alternately.
    When the ambient temperature exceeds the recommended range, the  (Battery status) icon will appear on the status bar and charging will be forcibly terminated. This is done as a precaution and it's not a malfunction.
    The recommended operating temperature range is 5 °C to 35 °C (41 ºF to 95 ºF). We recommend that you use the device in an environment within the recommended temperature range.
    For other charging precautions, refer to the following Help Guides.
