Article ID : 00238717 / Last Modified : 05/04/2022Print
How to connect a Walkman player to a Headphone Amplifier with a USB Type-C port
    What do I need?
    • Micro-USB cable: Standard-A-male to Micro-B-male
      NOTE: For the PHA-2A, a Micro USB cable is supplied with the product.
    • USB cable or USB conversion adapter: Standard-A-female to Micro-C-male.
    Connection method
    For the PHA-2A:
    Connection diagram
    1. PHA-2A
    2. Walkman
    3. Micro USB cable (supplied)
    4. USB cable or USB conversion adapter(commercially-available)
    Refer to the following for the connection method.
    1. Connect a USB cable or USB conversion adapter to the USB Type-C port of the Walkman.
    2. Connect a Micro USB cable to Xperia/WALKMAN/PC port of PHA-2A.
    3. Connect the USB cable or USB conversion adapter to the Micro USB cable.
    NOTE: The connected the Walkman will not be charged even if the USB AC adapter AC-UD20 (sold separately) is used.
    For the TA-ZH1ES:
    Connection diagram
    1. TA-ZH1ES
    2. Walkman
    3. Micro USB cable(commercially-available)
    2. Connect a Micro USB cable to WALKMAN port of TA-ZH1S.
    NOTE: The connected Walkman will not be charged.
