Setting the Reminder function
- Press the GUIDE button on the TV remote control.
- Select the TV show you would like to watch, then press the Enter button.
- Press the Down arrow button to select Reminder, then press the Enter button.
- Select Set timer then press the Enter button.
Cancel the Reminder function
For models released in 2020
- Press the Up arrow button first, and then Left arrow button until you will hear Tools, then press the Enter button.
- Select Timer list then press the Enter button.
- Press the BACK button.
- Press the Down arrow button to select Reminder list then press the Enter button.
- Press the Right arrow button to select the TV show you would like to cancel then press the Enter button.
- Select Cancel Timer then press the Enter button.
- Since there are two choices, which are CANCEL and Delete, press the Right arrow button to select Delete then press the Enter button.
For other models
- Select Timer list by one of the following procedures.
- Press the Up arrow button first, and then Left arrow button until you will hear Tools, then press the Enter button. Select Timer list then press the Enter button.
- Press the Left arrow button to move to the side menu. Press the Down arrow button to select Timer list then press the Enter button.
- Press the Down arrow button to select Reminder list then press the Right arrow button to select the TV show you would like to cancel then press the Enter button.
- Since there are two choices, which are CANCEL and OK, press the Right arrow button to select OK then press the Enter button.
