Article ID : 00257783 / Last Modified : 20/01/2026Print
    Product dimensions for XG85 Android TV model series
    These dimensions are approximate values.
    For the dimensions when using the Sony Wall-Mount Bracket, refer to the Wall-Mount Bracket Installation Information on the product support website.
    Using a stand
    TV dimensions labeled A through G
    (mm)
    Model (KD-)ABCDEFG
    85XG85xx1909109714381175100433175
    75XG85xx16739641230103171358145
    65XG85xx1450837105989967316131
    55XG85xx123171499677666316131
    Mounting on a wall
    (mm)
    Model (KD-)ABCDEF
    85XG85xx19091097400400755345
     75XG85xx1673963400300637419
    65XG85xx1450836300300575364
    55XG85xx1231713300200466296
    G: M6 holes for wall mount bracket
    *Refer to the instruction manual for screw length information.
    For product protection and safety reasons, Sony recommends that mounting your TV on the wall is done by Sony dealers or licensed contractors.
    Make sure you use the specified Wall-Mount Bracket. For details, refer to the TV manual.
