Article ID : 00252279 / Last Modified : 20/01/2026Print
    How to record a video in slow motion with Cinema Pro
    Follow these steps to record a video in slow motion with Cinema Pro:
    1. Tap the FPS menu.
    2. Select 120fps to record a video in slow motion.
     Notes:
    • The FPS menu sets the camera's fps (recording frame speed). You can select either 120fps or the same fps value as the Project FPS (Playback frame speed). If you select 120fps, the video is recorded in slow motion, and its slow ratio depends on the Project FPS.
      • Example: With a "Project FPS" of 23.98 and an "FPS" of 120(24), the slow ratio will be "x5.0" (= 120/24).
    • The following models support 120fps only with a 24mm lens:
      • Xperia 1 II
      • Xperia 5 II
      • Xperia 1 III
      • Xperia 5 III
      • Xperia PRO
      • Xperia PRO-I
    • The Xperia 1 IV and Xperia 5 IV support 120fps with all lenses.
