Article ID : 00257416 / Last Modified : 10/02/2021Print
How to setup the TV to support a 4K 120Hz signal from another device.
    You will need to set the TV HDMI Signal Format to Enhanced Format for your source device to recognise the 4K 120Hz capability of the TV.
    Note: Make sure your device is connected to the HDMI 3 or HDMI 4 input on the TV using the supplied Certified Premium HDMI cable.
    To set the HDMI Signal Format to Enhanced Format
