Article ID : 00294169 / Last Modified : 25/08/2026Print
    An app has disappeared from the Application screen, how to find it? (Android 9 or higher)
    What are the reasons an app has disappeared from the application screen?
    Image of smartphone holding with a hand and a question mark on screen to indicate nothing appeared.
    • The app has been deleted
    • The app has been disabled
    • Software bug or an error
    Try the following methods one after the other. Verify whether the problem is solved after each method, before trying the next one.
    If your Android version is Android 9 and above, up to 11, try the following methods.
