What is the difference between the Imaging Edge Webcam PC application and the USB streaming function?
When connected to a compatible camera, the USB streaming function offers enhanced video and audio capabilities compared to Imaging Edge Webcam software.
Streaming Method | Software Required | Video | Audio | Resolution |
Imaging Edge Webcam | Yes | MJPEG | No - Must use an external or the computer's microphone. | 1024 x 576 pixels |
USB Streaming *1 | No | MJPEG or YUV420 *2 |
Yes - Camera's built-in microphone. PCM 48 kHz, 16 bit, 2ch |
4k(2160p, HD(1080p), or HD(720p) *2 |
- *1 If you use the ZV-1, DSC-RX0M2 or ILCE-7C, update to the latest System Software (Firmware).
- *2 Available video formats differ depending on the camera model. For details, refer to the camera Operating Instructions or Help Guide.
If you need information on setup steps, select your preferred streaming method:
