Article ID : 00380204 / Last Modified : 03/06/2026Print
    Under what conditions does the DSEE Ultimate function work?
    The DSEE Ultimate function is compatible with the 2-channel digital input signals of 44.1 kHz or 48 kHz sampling frequency. The sampling frequency/bit depth after upscaling is up to 96 kHz/32 bit.
    Note: The DSEE Ultimate function does not work in the following conditions:
    • When the music is playing on a network using the AirPlay or 360 Reality Audio service
    • When the Sound field is set to ON
    • When Dolby Speaker Virtualizer or DTS Neural:X is selected in the Sound Field Setting
    • When Automatically adjust volume is set to ON
    • When the Auto Low Latency Mode (ALLM) is enabled
