Article ID : 00409990 / Last Modified : 27/08/2026Print
    The BRAVIA TV turns on or off automatically.
    IMPORTANT: This article only applies to specific products. Please check the Applicable Products of this article.
    Follow the steps below to troubleshoot this issue.
    1. Update the TV software to the latest version
    Updating the TV software may fix specific issues.
    2. Check the TV settings
    If the TV turns on or off at regular intervals (e.g., every 30 minutes to an hour), check the TV settings.
    3. Perform a power reset
    Refer to the How to restart (reset) a Google TV™ article.
    4. Reset the TV to the original factory settings
    Refer to the How to reset the Google TV to factory settings article.
    The troubleshooting steps listed above should resolve your issue. If the above steps do not help, the TV may need a service.
