Article ID : 00414737 / Last Modified : 23/10/2026Print
    The focal length shown for a captured image differs depending on whether you check it on the camera or on a computer.
    Different devices and apps handle decimal places differently (rounding down vs. rounding to the nearest) so the displayed focal length may differ.
    To check the focal length of an image you have shot, refer to "Lens Focal Length" under Image Properties in Imaging Edge Desktop (Viewer).
