Article ID : 00172788 / Last Modified : 16/01/2026Print
    When connecting a Home Theater system or AV amplifier via HDMI, 4K picture isn't displayed
    For Models: HT-CT780/HT-NT3/HT-RT5/HT-ST9/HT-XT3/STR-DN860/STR-DN1060
    • Some of the 4K signals are supported.
    • HDR is not supported.
    • When you play 4K signals with copyright protection technology, check that you use an HDMI jack compatible with HDCP2.2.
    Although the following signal is supported, HDR signals are not supported.
      Resolution Frame RateColor Space   Bit depth
     4K
    4096 × 2160p
    3840 × 2160p
     50/59.94/60 HZ YCbCr 4:2:0 8bit
     23.98/24/25/29.97/30 Hz  RGB 4:4:4
    YCbCr 4:4:4
     8bit
     YCbCr 4:2:2 8/10/12 bit
    When the picture of standard formats such as 4K/60p YCbCr 4:2:0 8bit is not displayed, check the following:
    1. Check that you connect with a High-Speed HDMI cable with Ethernet (or a Premium High-Speed HDMI cable with Ethernet that supports 18Gbps).
    2. Check that your TV supports the high-definition 4K video format.
    3. Check that HDMI Signal Format for your High-Definition BRAVIA TV 4K is set to Standard Format.
      IMPORTANT: 4K signals may not be output depending on the contents or specifications of video output devices such as PlayStation4 Pro.
      For details, refer to the operating instructions of the output device.
