Article ID : 00407355 / Last Modified : 13/10/2026Print
    The BRAVIA Connect app repeatedly asks me to “Reconnect the HDMI cable” during setup
    If the BRAVIA Connect app repeatedly displays “Reconnect the HDMI cable” and the initial setup cannot be completed, the HDMI connection between the TV and the soundbar or home theater system may not be detected correctly.
    Check the following:
    1. Make sure the HDMI cable is securely connected to both the TV and the home theater system or soundbar. Disconnect the HDMI cable, then firmly reconnect it to both devices.
    2. Make sure the HDMI cable is connected to the correct HDMI terminals on both devices. Use the terminals labeled “eARC/ARC” where available.
    3. Use the HDMI cable supplied with the soundbar or home theater system. If you do not have the supplied cable, try another HDMI cable to check whether the connection is detected.
    4. If other audio devices or an HDMI selector is connected to the HDMI terminals on the TV, soundbar, or home theater system, disconnect them and retry the setup.
      Hint: Use a direct HDMI connection between the TV and the soundbar or home theater system. HDMI selectors are not supported and are not guaranteed to work.
    Reconnect the HDMI cable message in the BRAVIA Connect app
