Article ID : 00198887 / Last Modified : 30/03/2021Print
    What is a RAW image file?
    "RAW" has the same meaning of "raw" such as in "raw vegetables," and is not an abbreviation like JPEG (Joint Photographic Experts Group).
    Digital cameras generally perform digital processing to the output signals from image sensor, and create JPEG images. Meanwhile, RAW is a data format whose processing parameters can be adjusted freely by photographers.
    NOTE: RAW data taken with Sony cameras are saved with an extension "ARW".
    https://support.d-imaging.sony.co.jp/www/disoft/int/idc/intro/raw.html
    Frequently Asked Questions about RAW file
    Basic Information
    Application Information
    Imaging Edge Desktop (Image Data Converter successor)
    https://support.d-imaging.sony.co.jp/app/imagingedge/
