Article ID : 00257862 / Last Modified : 04/06/2026Print
    Which RAW recording format should I use for my digital camera?
    You can choose from four RAW recording formats depending on the image quality, shooting speed, and development speed you want to use.
    RAW recording formatRecommended when...
    Uncompressed RAWYou want high image quality and fast RAW processing, as this format processes faster in development software than Lossless Compressed RAW.
    Lossless Compressed RAWYou want to record with the same image quality as Uncompressed RAW but with a smaller file size
    Compressed RAW (HQ)You want to record with higher image quality than Compressed RAW
    Compressed RAWYou want to limit the file size or shoot continuously at the maximum speed
    Note: Supported functions vary depending on your camera.
