Article ID : 00363787 / Last Modified : 19/08/2025Print
    Eco and energy saving
    • Power Consumption (Off Mode): not available
    • Power Consumption (Standby Mode / Low Power Mode): 0.5 W
    • Power Consumption (Networked Standby Mode) - Terminals: 0.5 W (Audio cable, Bluetooth® function, 2.4 GHz, maximum power consumption configuration)
    • Off Mode / Standby Mode / Low Power Mode Activated: This unit enters low power mode immediately after charging is completed when connected to the AC adaptor.
    • Networked Standby Mode Activated - Terminals: This unit enters networked standby mode immediately after playback is paused. *When this unit is connected to the AC adaptor, networked standby mode and low power mode are considered to be the same state, as the power consumption in networked standby mode is 0.5 W or less.
    • Wireless Network(s) On/Off Switch: You can connect to the unit with a paired transceiver (YY2988) when the unit turns on.
      You can turn off the wireless function by inserting the supplied headphone cable into the headphone cable input jack. Remove the headphone cable to turn on the wireless function.
    • Technical characteristics of the AC adaptor that can be used with the product: A commercially available USB AC adaptor capable of supplying an output current of 0.5 A (500 mA) or more.
