Article ID : 00177806 / Last Modified : 04/06/2026Print
    Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2015-2026 models)
    On this page you can find an overview of all line-ups and their respective Wall-Mount Brackets and screw hole distance measurements.
    You can check your model year with the model series name or model name. If you're unsure about the release year of your TV, please use the "Ctrl + F" (Windows) or "Command + F" (Macbook), or the page search functionality on your smartphone.
    2026 models (see the compatibility chart for 2026)
    • BRAVIA 9 II (XR90M2): (K-115XR95M2 / K-85XR95M2 / K-75XR95M2 / K-65XR95M2)
    • BRAVIA 7 II (XR70M2): (K-98XR75M2 / K-85XR75M2 / K-75XR75M2 / K-65XR75M2 / K-55XR75M2 / K-50XR75M2 / K-75XR79M2 / K-65XR79M2 / K-55XR79M2)
    • BRAVIA 3 II (XR30M2): (K-100XR35M2 / K-85XR35M2 / K-75XR35M2 / K-75XR39M2 / K-75XR32M2 /  K-65XR39M2 / K-65XR35M2 / K-65XR32M2 /  K-55XR39M2 / K-55XR35M2 / K-55XR32M2 / K-50XR39M2 / K-50XR35M2 / K-50XR32M2 / K-43XR39M2 / K-43XR35M2 / K-43XR32M2)
    2025 models (see the compatibility chart for 2025)
    • BRAVIA 8 II (XR80): (K-65XR8M2 / K-55XR8M2)
    • BRAVIA 5 (XR50): (K-98XR5 / K-85XR5 / K-75XR5 / K-65XR5 / K-55XR5)
    • BRAVIA 3 (S30): (K-85S3 / K-75S3 / K-65S3 / K-55S3 / K-50S3 / K-43S3)
    2024 models (see the compatibility chart for 2024)
    • BRAVIA 9: (K-85XR90 / K-75XR90)
    • BRAVIA 8: (K-77XR80 / K-77XR83 / K-77XR84 / K-65XR80 / K-55XR80 / K-55XR83 / K-55XR84 / K-65XR83 / K-65XR84)
    • BRAVIA 7: (K-85XR70 / K-75XR70 / K-65XR70 / K-55XR70)
    2023 models (see the compatibility chart for 2023)
    • A95L Series: (XR-77A95L / XR-65A95L / XR-55A95L)
    • A84L Series: (XR-83A84L / XR-77A84L / XR-65A84L / XR-55A84L)
    • A83L Series: (XR-77A83L / XR-65A83L / XR-55A83L)
    • A80L Series: (XR-83A80L / XR-77A80L / XR-65A80L / XR-55A80L)
    • X95L Series: (XR-85X95L / XR-75X95L / XR-65X95L)
    • X90L Series: (XR-98X90L / XR-85X90L / XR-75X90L / XR-65X90L / XR-55X90L)
    • X85L Series: (KD-75X85L / KD-65X85L / KD-55X85L)
    • X80L Series: (KD-85X80L / KD-75X80L / KD-65X80L / KD-55X80L / KD-50X80L / KD-43X80L)
    • X75WL Series: (KD-75X75WL / KD-65X75WL / KD-55X75WL / KD-50X75WL / KD-43X75WL)
    2022 models (see the compatibility chart for 2022)
    • A95K Series: (XR-65A95K / XR-55A95K)
    • A90K Series: (XR-48A90K / XR-42A90K)
    • A84K Series: (XR-77A84K / XR-65A84K / XR-55A84K)
    • A83K Series: (XR-77A83K / XR-65A83K / XR-55A83K)
    • A80K Series: (XR-77A80K / XR-65A80K / XR-55A80K)
    • A75K Series: (XR-65A75K / XR-55A75K)
    • Z9K Series: (XR-85Z9K / XR-75Z9K)
    • X95K Series: (XR-85X95K / XR-75X95K / XR-65X95K)
    • X94K Series: (XR-75X94K / XR-65X94K / XR-55X94K)
    • X94S Series: (XR-50X94S)
    • X93K Series: (XR-75X93K / XR-65X93K / XR-55X93K)
    • X92K Series: (XR-75X92K / XR-65X92K / XR-55X92K / XR-50X92K)
    • X90K Series: (XR-85X90K / XR-75X90K / XR-65X90K / XR-55X90K)
    • X90S Series: (XR-55X90S / XR-50X90S)
    • X89K Series: (KD-85X89K / KD-75X89K / KD-65X89K / KD-55X89K / KD-50X89K / KD-43X89K)
    • X85K Series: (KD-85X85K / KD-75X85K / KD-65X85K / KD-55X85K / KD-50X85K / KD-43X85K)
    • X85TK Series: (KD-85X85TK / KD-75X85TK / KD-65X85TK / KD-55X85TK / KD-50X85TK / KD-43X85TK)
    • X82K Series: (KD-75X82K / KD-65X82K / KD-55X82K / KD-50X82K / KD-43X82K)
    • X81K Series: (KD-75X81K / KD-65X81K / KD-55X81K / KD-50X81K / KD-43X81K)
    • X80K Series: (KD-65X80K / KD-55X80K / KD-50X80K / KD-43X80K)
    • X73K Series: (KD-50X73K / KD-43X73K)
    • X72K Series: (KD-50X72K / KD-43X72K)
    2021 models (see the compatibility chart for 2021)
    • A90J Series: (XR-65A90J / XR-55A90J)
    • A84J Series: (XR-77A84J / XR-65A84J / XR-55A84J)
    • A83J Series: (XR-77A83J / XR-65A83J / XR-55A83J)
    • A80J Series: (XR-77A80J / XR-65A80J / XR-55A80J)
    • Z9J Series: (XR-85Z9J / XR-75Z9J)
    • X95J Series: (XR-85X95J / XR-75X95J / XR-65X95J)
    • X94J Series: (XR-75X94J / XR-65X94J / XR-55X94J / XR-50X94J)
    • X93J Series: (XR-75X93J / XR-65X93J / XR-55X93J / XR-50X93J)
    • X92J Series: (XR-75X92J / XR-65X92J / XR-55X92J / XR-50X92J)
    • X90J Series: (XR-75X90J / XR-65X90J / XR-55X90J / XR-50X90J)
    • X89J Series: (KD-75X89J / KD-65X89J / KD-55X89J / KD-50X89J / KD-43X89J)
    • X85J Series: (KD-85X85J / KD-75X85J / KD-65X85J / KD-55X85J / KD-50X85J / KD-43X85J)
    • X85TJ Series: (KD-85X85TJ / KD-75X85TJ / D-65X85TJ / KD-55X85TJ / KD-50X85TJ / KD-43X85TJ)
    • X82J Series: (KD-75X82J / KD-65X82J / KD-55X82J / KD-50X82J / KD-43X82J)
    • X81J Series: (KD-75X81J / KD-65X81J / KD-55X81J / KD-50X81J / KD-43X81J)
    • X80J Series: (KD-65X80J / KD-55X80J / KD-50X80J / KD-43X80J)
    • W804 Series: (KD-32W804)
    • W800 Series: (KD-32W800)
    2020 models (see the compatibility chart for 2020)
    • A9 Series: (KD-48A9)
    • A89 Series: (KD-65A89 / KD-55A89)
    • A87 Series: (KD-65A87 / KD-55A87)
    • A85 Series: (KD-65A85 / KD-55A85)
    • A8 Series: (KD-65A8 / KD-55A8)
    • ZH8 Series: (KD-85ZH8 / KD-75ZH8)
    • XH9505 Series: (KD-85XH9505 / KD-75XH9505 / KD-65XH9505 / KD-55XH9505 / KD-49XH9505)
    • XH9299 Series: (KD-75XH9299 / KD-65XH9299 / KD-55XH9299)
    • XH9296 Series: (KD-75XH9296 / KD-65XH9296 / KD-55XH9296)
    • XH9288 Series: (KD-75XH9288 / KD-65XH9288 / KD-55XH9288)
    • XH9196 Series: (KD-49XH9196 / KD-43XH9196)
    • XH9096 Series: (KD-85XH9096 / KD-75XH9096 / KD-65XH9096 / KD-55XH9096)
    • XH9077 Series: (KD-65XH9077 / KD-55XH9077)
    • XH9005 Series: (KD-75XH9005 / KD-65XH9005 / KD-55XH9005)
    • XH8599 Series: (KD-49XH8599 / KD-43XH8599)
    • XH8596 Series: (KD-49XH8596 / KD-43XH8596)
    • XH8588 Series: (KD-49XH8588 / KD-43XH8588)
    • XH8577 Series: (KD-49XH8577)
    • XH8505 Series: (KD-49XH8505 / KD-43XH8505)
    • XH8196 Series: (KD-65XH8196 / KD-55XH8196 / KD-49XH8196 / KD-43XH8196)
    • XH8096 Series: (KD-85XH8096 / KD-75XH8096 / KD-65XH8096 / KD-55XH8096 / KD-49XH8096 / KD-43XH8096)
    • XH8077 Series: (KD-65XH8077 / KD-55XH8077 / KD-49XH8077 / KD-43XH8077)
    • XH8005 Series: (KD-55XH8005 / KD-49XH8005 / KD-43XH8005)
    • X7056 Series: (KD-65X7056 / KD-55X7056 / KD-49X7056 / KD-43X7056)
    • X7055 Series: (KD-65X7055 / KD-55X7055 / KD-49X7055 / KD-43X7055)
    • X7053 Series: (KD-65X7053 / KD-55X7053 / KD-49X7053 / KD-43X7053)
    • X7052 Series: (KD-65X7052 / KD-55X7052 / KD-49X7052 / KD-43X7052)
    2019 models (see the compatibility chart for 2019)
    • AG9 Series: (KD-77AG9 / KD-65AG9 / KD-55AG9)
    • AG8 Series: (KD-65AG8 / KD-55AG8)
    • XG9505 Series: (KD-85XG9505 / KD-75XG9505 / KD-65XG9505 / KD-55XG9505)
    • XG9005 Series: (KD-49XG9005)
    • XG8796 Series: (KD-75XG8796 / KD-65XG8796 / KD-55XG8796)
    • XG8599 Series: (KD-75XG8599 / KD-65XG8599 / KD-55XG8599)
    • XG8596 Series: (KD-85XG8596 / KD-75XG8596 / KD-65XG8596 / KD-55XG8596)
    • XG8588 Series: (KD-75XG8588 / KD-65XG8588 / KD-55XG8588)
    • XG8577 Series: (KD-65XG8577 / KD-55XG8577)
    • XG8505 Series: (KD-75XG8505 / KD-65XG8505 / KD-55XG8505)
    • XG8399 Series: (KD-49XG8399 / KD-43XG8399)
    • XG8396 Series: (KD-49XG8396 / KD-43XG8396)
    • XG8388 Series: (KD-49XG8388 / KD-43XG8388)
    • XG8377 Series: (KD-49XG8377)
    • XG8305 Series: (KD-49XG8305 / KD-43XG8305)
    • XG8196 Series: (KD-65XG8196 / KD-55XG8196 / KD-49XG8196 / KD-43XG8196)
    • XG8096 Series: (KD-75XG8096 / KD-65XG8096 / KD-55XG8096 / KD-49XG8096 / KD-43XG8096)
    • XG7096 Series: (KD-65XG7096 / KD-55XG7096 / KD-49XG7096 / KD-43XG7096)
    • XG7093 Series: (KD-65XG7093 / KD-55XG7093 / KD-49XG7093 / KD-43XG7093)
    • XG7077 Series: (KD-65XG7077 / KD-55XG7077 / KD-49XG7077 / KD-43XG7077)
    • XG7073 Series: (KD-65XG7073 / KD-55XG7073 / KD-49XG7073 / KD-43XG7073)
    • XG7005 Series: (KD-65XG7005 / KD-55XG7005 / KD-49XG7005 / KD-43XG7005)
    • XG7004 Series: (KD-65XG7004 / KD-55XG7004 / KD-49XG7004 / KD-43XG7004)
    • XG7003 Series: (KD-65XG7003 / KD-55XG7003 / KD-49XG7003 / KD-43XG7003)
    • XG7002 Series: (KD-65XG7002 / KD-55XG7002 / KD-49XG7002 / KD-43XG7002)
    • WG665 Series: (KDL-50WG665 / KDL-43WG665)
    • WG663 Series: (KDL-50WG663 / KDL-43WG663)
    • ZG9 Series: (KD-98ZG9 / KD-85ZG9)
    2018 models (see the compatibility chart for 2018)
    • AF9 Series: (KD-65AF9 / KD-55AF9)
    • AF8 Series: (KD-65AF8 / KD-55AF8)
    • WF804 Series: (KDL-49WF804 / KDL-43WF804)
    • WF805 Series: (KDL-49WF805 / KDL-43WF805)
    • XF7596 Series: (KD-65XF7596 / KD-55XF7596 / KD-49XF7596 / KD-43XF7596)
    • XF8096 Series: (KD-55XF8096 / KD-49XF8096 / KD-43XF8096)
    • XF8305 Series: (KD-70XF8305 / KD-60XF8305)
    • XF8505 Series: (KD-65XF8505 / KD-55XF8505 / KD-49XF8505 / KD-43XF8505)
    • XF8577 Series: (KD-65XF8577 / KD-55XF8577 / KD-49XF8577 / KD-43XF8577)
    • XF8588 Series: (KD-65XF8588 / KD-55XF8588 / KD-49XF8588 / KD-43XF8588)
    • XF8596 Series: (KD-85XF8596 / KD-75XF8596 / KD-65XF8596 / KD-55XF8596 / KD-49XF8596 / KD-43XF8596)
    • XF8599 Series: (KD-65XF8599 / KD-55XF8599 / KD-49XF8599 / KD-43XF8599)
    • XF8796 Series: (KD-65XF8796 / KD-55XF8796 / KD-49XF8796 / KD-43XF8796)
    • XF9005 Series: (KD-75XF9005 / KD-65XF9005 / KD-55XF9005 / KD-49XF9005)
    • ZF9 Series: (KD-75ZF9 / KD-65ZF9)
    2017 models (see the compatibility chart for 2017)
    • A1 Series: (KD-65A1 / KD-55A1)
    • XE93xx_XE94xx Series: (KD-75XE9405 / KD-65XE9305 / KD-55XE9305)
    • XE90xx Series: (KD-75XE9005 / KD-65XE9005 / KD-55XE9005 / KD-49XE9005)
    • XE85xx Series: (KD-65XE8505 / KD-55XE8505)
    • XE80xx Series: (KD-49XE8005 / KD-43XE8005)
    • XE70xx Series: (KD-65XE7005 / KD-65XE7003 / KD-65XE7002 / KD-55XE7005 / KD-55XE7003 / KD-55XE7002 / KD-55XE7000 / KD-49XE7005 / KD-49XE7003 / KD-49XE7002 / KD-49XE7000 / KD-43XE7005 / KD-43XE7003 / KD-43XE7002 / KD-43XE7000)
    • WE75x Series: (KDL-49WE755 / KDL-49WE753 / KDL-49WE750 / KDL-43WE755 / KDL-43WE753 / KDL-43WE750)
    • WE61x_WE66x Series: (KDL-49WE665 / KDL-49WE663 / KDL-49WE660 / KDL-40WE665 / KDL-40WE663 / KDL-40WE660 / KDL-32WE615 / KDL-32WE613 / KDL-32WE610)
    • RE4xx Series: (KDL-40RE455 / KDL-40RE453 / KDL-40RE450 / KDL-32RE405 / KDL-32RE403 / KDL-32RE400)
    2016 models (see the compatibility chart for 2016)
    • ZD9 Series: (KD-100ZD9 / KD-75ZD9 / KD-65ZD9)
    • XD93xx_XD94xx Series: (KD-75XD9305 / KD-65XD9305 / KD-55XD9405)
    • XD85xx Series: (KD-85XD8505 / KD-75XD8505 / KD-65XD8599 / KD-65XD8577 / KD-65XD8505 / KD-55XD8599 / KD-55XD8588 / KD-55XD8577 / KD-55XD8505)
    • XD83xx Series: (KD-49XD8305 / KD-43XD8305)
    • XD80xx Series: (KD-55XD8005 / KD-49XD8099 / KD-49XD8088 / KD-49XD8077 / KD-49XD8005 / KD-43XD8099 / KD-43XD8088 / KD-43XD8077 / KD-43XD8005)
    • XD75xx Series: (KD-65XD7505 / KD-65XD7504)
    • XD70xx Series: (KD-55XD7005 / KD-55XD7004 / KD-49XD7005 / KD-49XD7004)
    • SD85xx_SD80xx Series: (KD-65SD8505 / KD-55SD8505 / KD-50SD8005)
    2015 models (see the compatibility chart for 2015)
    • X93xxC_X94xxC Series: (KD-75X9305C / KD-65X9305C / KD-55X9405C)
    • X90xxC_X91xxC Series: (KD-75X9005C / KD-65X9005C / KD-55X9105C)
    • X85xxC Series: (KD-75X8505C / KD-75X8501C / KD-65X8509C / KD-65X8508C / KD-65X8507C / KD-65X8505C / KD-65X8501C / KD-55X8509C / KD-55X8508C / KD-55X8507C / KD-55X8505C / KD-55X8501C)
    • X83xxC Series: (KD-49X8309C / KD-49X8308C / KD-49X8307C / KD-49X8305C / KD-49X8301C / KD-43X8309C / KD-43X8308C / KD-43X8307C / KD-43X8305C / KD-43X8301C)
    • X80xxC Series: (KD-55X8005C / KD-49X8005C)
    • S85xxC Series: (KD-65S8505C / KD-55S8505C)
    • S80xxC Series: (KD-65S8005C / KD-55S8005C)
