LinkBuds Clip (WF-LC900) | Usage tips
In this guide, we'll show you how to use your LinkBuds Clip (WF-LC900) earbuds. Learn how to pair and properly wear your earbuds, control them via touch or the Sony | Sound Connect app, connect to multiple devices, keep them clean, and troubleshoot issues.
Getting started
Put your earbuds into pairing mode, turn on Bluetooth on your device, then connect.
See our tips for wearing and adjusting your earbuds, and how to attach the fitting cushion for a proper fit.
Controls and settings
Play music, adjust the volume, switch listening modes, and access other features with just a few taps.
Easily adjust settings such as Listening Mode, Equalizer, 360 Reality Audio, and more.
Connecting to Bluetooth devices
Use the Sony | Sound Connect app to connect your earbuds to your smartphone and computer at the same time.
Learn how to switch audio between your smartphone and computer.
Care and troubleshooting
See our tips for safely cleaning your earbuds and case to prevent sound and charging issues.
Is your charging case flashing green, orange, blue, or not lighting up? Find out what these LED patterns mean.
Restart your Bluetooth devices or reset your earbuds to their default settings.
