LinkBuds Clip (WF-LC900) | Entering Bluetooth pairing mode
    To connect your earbuds to a smartphone, computer, Walkman, or other Bluetooth device, you first need to put them into pairing mode.
    Note: Your earbuds automatically enter pairing mode the first time you use them after purchase, and each time after they have been initialised.
    1. Place your earbuds in the charging case
      Make sure the L (left) and R (right) earbuds are placed in the matching slots.
    2. Press and hold the pairing button
      With the charging case lid open, press and hold the pairing button on the back for about 5 seconds. The blue LED flashes in a repeating two-blink pattern, and the earbuds enter pairing mode.
      You can now remove the earbuds from the charging case. When you put them in your ears, you will hear a notification sound, and the voice guidance will say "Pairing mode.”
    3. Choose your device and complete the Bluetooth pairing
      Select your device below to see the detailed pairing instructions.
