Article ID : 00162492 / Last Modified : 04/06/2026Print
My TV remote control isn't working properly or responding at all
    If you're experiencing issues with your TV remote control, this guide may be able to help.
    Note: Make sure you read the Before you start section first before continuing to the TV remote reset or troubleshooting guide.
    Before you start
    • In the case of a third-party tuner or set-top box, you may only be able to switch channels with the supplied third-party remote control. The original Sony remote will not work.
    • If the remote control isn't working properly after updating the TV system software, refer to this support article. (Only select models)
  • If an error is displayed when you press a remote control button related to Internet services such as YouTube™ or Netflix, check whether the TV is connected to the Internet correctly. For details about connecting to the Internet or troubleshooting, refer to this article: How to & Troubleshooting for Internet connection.
  • Top tip - our quick recommended solution (except for rechargeable remote control)
    Note: If your remote control has a USB-C port on the bottom, it is a rechargeable remote control, so please skip these steps.
    Before you troubleshoot, we recommend you try resetting the remote control first:
    1. Remove the batteries from the remote control.
      Note: Depending on the type of remote control, the procedure to open the battery compartment cover will vary. For details, refer to your TV manual.
    2. On the remote control, press the Power button for three seconds.
    3. Reinsert the batteries, making sure they are inserted with the correct polarity (- / +), then see if the issue is resolved.
    4. If the issue is not resolved, remove the batteries again and leave them out for approximately 1 minute. Then, reinsert the batteries.
    If the issue is resolved, the remote control may have temporarily stopped working due to poor battery contact or static electricity. If the issue continues, we advise you to go through each section of our complete troubleshooting guide below.
    Our complete troubleshooting guide
    First, check whether the problem is due to your TV or remote control. If the problem is due to the remote control, use it to help guide you through the following steps.
    Note: It's important that you start with STEP 1.
