Article ID : 00105105 / Last Modified : 12/01/2015Print
    When using both a USB memory device and the MirrorLink feature, the content in the USB device is not recognised. Can this be solved?
    This problem occurs when the USB memory device you wish to play content from is connected after establishing the connection of the MirrorLink feature.
    Connecting the USB memory device before starting the MirrorLink feature should solve the issue.
