If your camera displays a "Reinsert the memory card" or "No memory card" message, follow these steps to troubleshoot and resolve the issue:
Remove the Memory Card: Safely eject the memory card from the camera.
Inspect and Clean the Memory Card: Examine the card for any visible damage or dirt on the terminals. Gently clean the terminals using a dry cloth or cotton swab. Be careful not to touch the terminals with your fingers or any metal objects.
Reinsert the Memory Card: Place the memory card back into the camera, ensuring it is properly aligned and securely inserted.
Try a Different Memory Card: If the message still appears, test the camera with a different memory card to determine if the issue is with the card or the camera.
If these steps do not resolve the issue, your camera may require professional servicing.
