Article ID : 00155645 / Last Modified : 12/04/2023Print
How to adjust the date and time on an Android TV™ or Google TV™
    IMPORTANT: This article applies to Android TVs and Google TVs. For TVs other than Android TVs (2016 models or later) or Google TVs, refer to the How to adjust the date and time (other than Android TV) article.
    The date and time are usually set automatically because the BRAVIA TV retrieves the date and time information from the broadcast signals or the wifi. If there are no broadcast signals or network connections (wifi) available you may need to set the date and time manually.
    How to set the date and time automatically
    With the TV receiving a broadcast signal or connecting to the network, follow these steps to check the setting:
    1. Open the Settings screen. How to access Settings
    2. The next steps will depend on your TV menu options:
      • Select SystemDate & timeAutomatic date & time.
      • Select Device PreferencesDate & timeAutomatic date & time.
      • Select Date & timeAutomatic date & time.
    3. Set Automatic date & time to ON, Use broadcast time or Use network time (Use network-provided time).
      • The available options can vary depending on the TV.
      • If your TV has the Time synchronization setting in Date & time, set it to Use broadcast provided time or Use network-provided time.
    How to check the Time Zone setting
    If the time is not displayed correctly, there is a possibility that the Time Zone setting is not correct. Follow these steps to check the setting:
      • Select SystemDate & timeSet time zone.
      • Select Device PreferencesDate & timeTimeSet time zone.
        Note: If Time is not shown, select Set time zone.
      • Select Date & timeSet time zone.
      • Select Date & timeTimeAutomatic time zoneOff, then select Set time zone.
    3. Select your location.
    If you use a special network environment such as a VPN, the time on the TV may differ from the time of the location (area) where the TV is located.
    How to set the date and time manually
    1. Open the Settings screen. How to access Settings:
      • Select SystemDate & timeAutomatic date & timeOff.
      • Select Device PreferencesDate & timeAutomatic date & timeOff.
      • Select Date & timeAutomatic date & timeOff
    3. To set the date and time manually select Set date and Set time, or Date and Time.
