How do I display the time on the Home screen of my Sony's Android TV?
To display the time on the Home screen of your Sony's Android TV, the time must be set and the Info Banner setting must first be turned on.
How to display the Info Banner
- Press the HOME button on the remote.
- Select Settings.
- Select Channel Setup in the TV category.
- Set Info Banner to On.
How to set the time
If the BRAVIA TV is connected to a network:
- Select Settings.
- Under the System Preferences category, select Date & time.
- Set Automatic date & time to On.
- Set Time synchronization to Use network time.
If the BRAVIA TV is not connected to a network:
- Select Settings.
- Set Automatic date & time to Off.
- Manually adjust the Time and Date.
