Article ID : 00124651 / Last Modified : 19/06/2023Print
How do I change the time on my BRAVIA TV to adjust for Daylight Savings Time (DST)/Summer time?
    Depending on your situation, adjust the following settings.
    If Time synchronization is set to Use network-provided time
     NOTE: If you do not know your current setting, confirm it by selecting Time synchronization after step 3 below.
    Operate as follows to set the Time Zone.
    1. Press the HOME button on the remote.
    2. Select Settings.*
    3. Select Date & time in the SYSTEM PREFERENCES category.
    4. Select Time.
    5. Select Set time zone, then select the appropriate city.
    If the BRAVIA TV is not connected to the Internet
    Operate as follows to set the correct time.
    4. Set Automatic date & time to Off.
    5. Press the RETURN button to return to Date & time.
    6. Select Time.
    7. Select Set time zone, then select the appropriate city.
    8. Press the RETURN button to return to Time.
    9. Select Set time and set the correct time.
    *NOTEFor Android Oreo (OSV-O), the settings icon is located in the top right-hand corner.
