Article ID : 00144073 / Last Modified : 19/02/2016Print
How to stop HDD recording
    Use any of the following methods to stop recording.
    Using the infrared remote control:
    1. Change to the broadcast that is currently being recorded.
    2. Press the STOP button on the remote control.
    Using the Touchpad Remote Control:
    2. Press the Action Menu button on the remote control.
    3. Select REC STOP.
    From the Home menu:
    2. Select Program Guide in the Apps category.
    3. Select Timer list.
    4. Select the broadcast that is currently being recorded.
    5. Select Rec Stop.
