I cannot recognise or register the USB HDD for recording
Please check the following:
- Make sure that the USB HDD is compatible with Sony’s Android TV for recording.
For details, refer to the following Q&A:
What types of USB hard disk drives are compatible with Android TV? - Make sure that the USB HDD is connected to the blue USB port which is labelled HDD REC.
NOTE: Connecting the USB HDD device via a USB hub is not supported. - Make sure that the USB HDD is not recognised as Device storage.
- Display Storage & reset to check that the USB HDD is not recognised as Device storage.
- Press the Home button on the remote.
- Select Settings.
- Select Storage & reset in the TV category.
NOTE: If the USB HDD is recognised as a recording device correctly, it is displayed as HDD for recording or nothing is displayed on the Storage & reset screen. The displaying procedures are different depending on the model or software version of the TV.
- If the USB HDD is registered as Device storage (Not registered as the HDD for recording), please format the USB HDD and register it for recording with the following method.
WARNING: There is a risk of hardware damage. Please don’t remove the HDD while formatting the USB HDD. Also, there is a risk of data loss. Make sure that you perform a backup before formatting.- Press the Home button on the remote.
- Select Settings.
- Select the USB HDD registered as Device storage.
- Select Erase & format.
- Select Format.
- Connect the USB HDD to the blue USB port which is labelled with HDD REC.
- When the USB drive connected message appears on the screen, then select Register for recording and press the Enter button. Then, follow the screens to complete registering of the HDD.
- Perform HDD performance check with the following method.
- Select Settings.
- Select Recording device Setup in the Network & Accessories category.
- Perform HDD performance check.
- Disconnect and connect the USB cable for the USB HDD.
WARNING: There is a risk of hardware damage. Before disconnecting the cable, make sure that the HDD is turned off. If the USB HDD is not turned off after waiting a while, check that the access lamp is not flashing (lit only) when disconnecting the cable. If you disconnect the cable while the access lamp is flashing, it may damage the HDD. - Unplug and plug in the TV power cord (mains lead).
WARNING: There is a risk of hardware damage. Before unplugging the cord, make sure the USB HDD is turned off. If the USB HDD is not turned off after waiting for a while, check that the access lamp is not flashing (lit only) when disconnecting the cord. If you disconnect the cord while the access lamp is flashing, it may damage the HDD.
