How to use the Twin Picture function on Sony's Android TV?
To display two pictures, follow the steps below:
STEP 1: Select the HDMI input that the device is connected to.
- Press the HOME button on the remote.
- Select Inputs.
- Select HDMI 1-4.
STEP 2: Select Twin Picture from the ACTION MENU.
- Press the ACTION MENU button on the remote.
- Select Twin Picture.
STEP 3: To end Twin Picture mode, select Single Picture from the ACTION MENU.
NOTES:
- The TV cannot enter Twin Picture mode unless an HDMI input is selected
- The only signals that can be displayed in Twin Picture mode are Digital 2K and analogue signals
- The Twin Picture display function is available via a software update . Update to the latest software, and then check whether it is displayed in the menu.
