Article ID : 00173766 / Last Modified : 11/04/2022Print
What is Panel calibration?
    Generally, due to the characteristics of the materials used for organic EL displays to achieve high-definition imaging, the display is susceptible to screen image retention.
    Panel calibration is a function that optimizes the screen and reduces  image retention or enhances the image in dark scenes.
    NOTE: Panel calibration is performed automatically a few hours after the power is turned off with a remote control.
