Article ID : 00283855 / Last Modified : 06/07/2023Print
How to use the TV as an alarm clock
    Wake up to your favourite TV program using the On Timer function as an alternative to the alarm clock on your phone. The TV On Timer is a great way to wake up without the temptation to snooze your alarm. Once the TV is on, it remains on, so you wake up starting your day on time.
    To set the On Timer
    Choose one of the steps below that matches your TV's menu path, as the steps may vary between TV models. If you need to confirm your TV model type, refer to the article How to check if your BRAVIA TV is a Google TV™, Android TV™, or other TV.
    Note:  The screenshots provided here are for reference only. The actual menu paths may differ according to your country, model, or firmware version.
    Google TV models
    Android TV models
    Other TV models
