Article ID : 00249712 / Last Modified : 22/10/2021Print
On timer (Turning on the TV at a specific time)
    This article applies only to specific products and operating systems (OS Android 9.0).
    For more details, check the Applicable Products and Categories section and refer to the article Which version of the Android™ OS is installed on my Android TV™?.
    Your TV will automatically turn on at a specific time using the On timer function. Waking up with your favourite morning news program is one example of the convenient use of this function. The On timer function also enables you to turn off the TV automatically after a certain duration of time, so you can leave your home without turning off the TV.
    We recommend you use the Screen reader function to set up the On timer function.
    Setting up the On timer
    1. Press the HOME button on the TV remote control.
    2. Select Timers, then press the Enter button.
    3. Press and hold the Up arrow button for about three seconds, press and hold the Right arrow button for about two seconds, leading the focus to the Settings icon. Then press the Left arrow button once to select the Timers icon.
    4. When you hear Timers, press the Enter button.
    • The Timers menu has a total of seven setting items: On timer/TimerDayTimeDurationInputsChannel, and Volume setup/TV on volume.
    • You can only make changes to DayTimeDurationInputsChannel, and Volume setup/TV on volume if you turn on the On timer/Timer setting.
     On timer / Timer
     Day
     Time
     Duration
     Inputs
     Channel
     Volume setup / TV on volume
    Notes:
    • Multiple settings are unavailable for the On timer function.
    • The Reminder function can keep up to 18 TV programs.
