Your TV will automatically turn on at a specific time when using the On timer function. Waking up to your favourite morning news programme is one example of how convenient this function is. What's more, the On timer function can also turn off the TV automatically after a certain period of time, so you can leave the house without turning off the TV.
Sony recommends you use the Talkback function to set up the On timer function.
Setting up the On timer
- On the TV remote control, press the HOME button.
- Press the arrow buttons to select Timers & Clock, then press the Enter button.
- To set up the On timer, press the Right arrow button to select Edit, then press the Enter button.
The Timers menu has seven setting items: Time, Day, Timer activation, Inputs, Channel, Volume setup, and Duration.
Time
- Using the Down arrow and Up arrow buttons, select the time to turn on your TV from 00 to 23, then press the Right arrow button.
- In the same way, use the Down arrow button to select the minutes from 00 to 59, press the Right arrow button, then press the Enter button.
- When you hear OK, press the Enter button. You will then hear the time you set.
Day
- Press the Down arrow button and when you hear Day, press the Enter button.
- Press the Down arrow button to select your preferred choice, then press the Enter button.
Timer activation
- Press the Down arrow button, and when you hear Timer activation, press the Enter button.
Inputs
- Press the Down arrow button, and when you hear Inputs, press the Enter button.
- Press the Down arrow button and select your preference from the available choices of broadcasting types and external inputs. Finally, press the Enter button.
Channel
If your choice of Inputs is a broadcast, select the channel as well.
- Press the Down arrow button, and when you hear Channel, press the Enter button.
- Press the Down arrow button, select your preferred channel from the available options, then press the Enter button. You will hear the channel name you chose.
Duration
- Press the Down arrow button, and when you hear Duration, press the Enter button.
- Press the Down arrow button and, from 1h to 23h, select the hours when you want to keep your TV on, then press the Enter button.
NOTES:
- Multiple settings are available by pressing the Up arrow button to select Add.
- The Reminder function can save up to 18 TV programmes.
