Article ID : 00200540 / Last Modified : 08/03/2022Print
The Amazon Alexa-enabled device responds with “Device is not found” and will not operate the TV
    Before you start
    Perform device discovery
    Step 1: Make sure device discovery was performed on the Amazon Alexa-enabled device
    Perform device discovery on the Amazon Alexa-enabled device.
    Step 2: Make sure the TV name is displayed in the Amazon Alexa app
    • If the TV name isn't displayed, perform the device discovery again in the TV Control Setup with Amazon Alexa app on the TV.
    • If the TV name is displayed, change it to a simple name that Alexa can easily recognise in the TV Control Setup with Amazon Alexa app on the TV.
    Change the TV name to an easy-to-recognise name.
    *Amazon and Alexa are trademarks of Amazon.com, Inc. or its affiliates.
