Article ID : 00238826 / Last Modified : 20/01/2026Print
    How to display or turn off the cassette tape screen
    You can switch the player playback screen to display a cassette tape screensaver. While displaying the cassette tape screen, the player will automatically turn off within 10 minutes to save power.
    To display the cassette tape screen
    1. On the HOME screen, select the Music Player.
    2. Select the music you want to play.
    3. Select the three-dotted options icon   at the top right of the screen.
    4. Tap the Display tape playback screen to enable the function (checkbox checked).
      Once a certain amount of time elapses without you touching the playback screen, the screen saver will be activated.
    NOTE: The type of cassette tape screen displayed depends on the track being played.
    How to turn off the cassette tape screen
    On the Music Player playback screen, select   (Options) and tap [Display tape playback screen] to turn off the checkmark.
